larger tires on 816 or not
catskillpond
wurtsboro ny
Junk yard called me today he had military tires come in 10 of them. Went down to look they were the super singles as you guys call them bolt pattern was right but did not take them asked him to save them. Im thinking larger tire big loss of power climbing hills in our area low range gets 50% use. Ole Girty needs all the power she can get when she hits a hill. Flat run she is a 68mph champ so any thoughts its a 1972 dont know if they changed transmission or clutch in later models to handle bigger tires Thanks Scott
73m819
328
gainesville, ga.
In fact I know some 816 owners that large on there truck then after a while took them back off, large tires are power robbers, the almost 36,000 lb 816 needs ALL the power it can get with that carp trans.
dmetalmiki
2,036
London England
68.MPH!? Curious to know what tires you are running at the moment. Standard 1100 or 1200? It would seem you are running (quite!) a few revolutions OVER the engine destruction speed.
Dan2001qx4
Banned
32
Greenfeild, IN
The usmc use m816s with 14r20 on them while in service. 14r20s make my m818 deuce bed cargo truck will run 65 to 68 with 14r20s pulling my mkt and m105 camper all day long just fine even up hill in 5 gear, granted a m816 weighs about the same empty as me all hooked up.
m818 cargo + mkt + m105a2 = m816
Just saying.
kubotaman
135
RI/MI
MVM had a article a year or two ago on a M816 with 14:00/20 and CTIS. It came from the military like that apparently.
catskillpond
wurtsboro ny
We ran 12 wreckers in Germany Pershing Missile units we got just about 60 mph as far as rpm not over normal. We first had quite of few of the gassers then some 543a2 when the 816s came that was the icing on the cake they were fairly new and had few problems Hydrovacs went on them regularly. Also front inner axle seals which they upgraded we could never get them out with a slide hammer, we took both axles out and drove them out with a camouflage pole used for the nets. Thanks Scott
