- 34,010
- 1,827
- 113
- GA Mountains
3 ways to address the delayed oil pressure issue.
1) Prelube. Has a storage tank and pump you can activate to prelube the oil system prior to start up. Works best!
2) Remote oil filter (mounted correctly). This elminates oil drain back into the crank case thus improving instant oil pressure on start up. Requires much fab work.
3) Spin on adapters. These allow you to use anti drain back filters. Oil can still drain forward but not nearly as much as the factory setup. Makes changing oil a breeze and does a good job of decreasing the oil pressureless time.
