- 559
- 785
- 93
- Canton, PA
Since June, my father and I have been restoring a M35A2. I have seen posts on here about people adding backup lights for visibility backing up at night. I decided to use LED lights for the better light quality and less draw on the alternator. I used a 27 Watt off road light from superbrightleds. Its very bright. Heavy duty. Water and shock proof. Its a 5.5 inch lense and a 30 degree angle. I wired it to a 24 volt switch in the cab with a blue LED indicator. It shines enough light to be seen from both mirrors on the truck. And it matches the LED brake lights and headlights. I also decided to add a REAR fog light. A lot of people go with dual backups. I knew this would be over kill especially with LEDs. I went with an Amber LED off road light from Northern Tool. It was the only round amber LED light I could find. Its only a 4 inch light but the amber really cuts through in bad weather. Its wired to an Amber LED 24 volt switch in the cab. I plan on using the light in fog or heavy rain and snow. The light shines back to alert people of the vehicle in front of them especially moving at a slow speed. The backup light is 2250 lumens the fog light is 1350 lumens.
