Lift kit for M1009
Horsepowerparts
Germany
We built a lot of M1009 with a 4" Lift Kit.
Front Springs and rear Blocks.
All are harder on the Front Springs than stock.
We do not have vibrations when we lift a M1009.
"Play in steering" is not good.
But these are other parts you must change.
Yes you must have a sway bar.
Regards
Steve
richingalveston
120
galveston/Texas
a lot of times the steering problem is in the steering shaft flex joint or rag joint as it is often referred to. it can be replaced with new and last for a while or most who do off road mods get a shaft with u-joints and not the rag joint.
http://www.borgeson.com/xcart/product.php?productid=1449&cat=34&page=1
the steering box can be worn out also but most of the time the shaft removes a lot of the play.
Lowering the case is not the best solution but it should not break anything. Try some axle shims they are cheep and it would be better to rotate your pinion angle a couple of degrees than drop the t case. you would still need the longer drive shaft.
nathus
13
Waterloo/ BELGIUM
Again,
Thanks a lot !
My back block are "angled" already. With this I mean that they aren't flat and horizontal they do what a degree shim would do on a flat one.
I'm also thinking about a kind of mix solution. Lower the t-case about half an inch and leghten a litlle my standard driveshaft.
Like I said before, om not driving off road but I want to keep the reliabilty of this truck as close as possible from the original one.
The steering is very enoying ; if something was broken or worn. It was there already before the lift. And till I put it in place it was fine enough for me to drive with.
But since the lift kit, it's not nice anymore.
Does somebody tried a dual steering stabilizer ?
Ilikemtb999
45
Denver, CO
If the angles match then they’ll be fine. Literally thousands of trucks are on the road with a 4” lift (or so the internet would have you believe). I have no idea why you’ve had such a difficult time considering you bought a kit. Ridiculous.
richingalveston
120
galveston/Texas
as stated as long as angles match and the joints don't bind you should not have driveshaft vibrations.
If the angle is two steep at the t-case the slip yoke can bind slightly and cause some vibrations when the suspension is being worked. noticed more at slow speeds. This gets worse as the slip yoke wears out and gets more play.
since your axle is already shimmed your left with dropping the t-case if you keep the u-joint at the t-case
CV joint and slip shaft are the next option.
4 inch lift is really the limit to u-joints on these vehicles especially the 1009. The longer 1008 drivetrain is a little more forgiving.
At 4 inches you have to play with all the variables to get it to work. And yes there are lots of lift kits out there but most manufacturers don't care about your driveshaft problems. sounds like you will have to drop the case slightly to get a comfortable ride.
I am a fan of the ord shackle flip because it addresses the driveshaft angle and corrects it in the best way possible in my opinion
My 5 inch lift is pushing the limits of my cv joint shaft. I still had to clearance the u-joint at the axle
nathus
13
Waterloo/ BELGIUM
Hi all,
I brought my rear driveshaft to a guy whi will extend it.
He told me that the u joint at the t case side ; is not replacable nor removeable.
It’s like « metled » does anybody has seen this already on a m1009 ????
Ilikemtb999
45
Denver, CO
If it’s original you just heat it up until the plastic melts out and then press/hammer it out. Otherwise if it’s been replaced there will be clips on the inside that need to be removed.
richingalveston
120
galveston/Texas
if the shop/guy cannot remove a factory u-joint, ask him what machine he is going to use to balance the shaft after he lengthens it. as posted you have to heat them.
I would suggest finding a real driveshaft shop....... sorry is see you are not in the states so a shop may not be an option.
just know the shaft has to be balanced once altered.
Rich
nathus
13
Waterloo/ BELGIUM
Hi,
Thanks to both of you !
Indeed and unfortunatly we don't have real driveshafts shops here.
The shop where I brought this is a shop for semi trucks , but he told me also that he had to balance it. So I guess he will do it like it has to be done.
He told me that the front u-joint (one the rear driveshaft) was probably an original, and was supposing that this old system was not made to be replaced.
I tried also to replace it when I replaced the rear one, but on the front I could'nt find any clip...
If I heat it to take it out, will I be able to put any Moog u -joint with clips in it ?
nathus
13
Waterloo/ BELGIUM
100% sure the joint can be replaced. the original joints were installed with a plastic pins
https://www.youtube.com/watch?v=CR1qqLo6XKA
see video
replacements have clips
Thank you for the video !
I'll have a look on mine because i'm not sure that I have the small plastics stuts like his on the side.
But it look the right way.
He is not showing which type of u - joint he uses to replace the orignal ones. With metal clips on the cup or same design as the one he took out ?
Regards
richingalveston
120
galveston/Texas
replacements have metal clips at the ends of the cups to hold them in.
I don't have the part numbers for the new ones. someone else here that has done a recent replacement may be able to help with part numbers.
nathus
13
Waterloo/ BELGIUM
Hi Guys,
I got my rear driveshaft back ; I'll put it back on monday, I realy hope this will solve the vibrations issues.
I choose to do a combination of two methods. I'll lower 0.5 inch my t-case and made my driveshaft a little longer... Let's cross the fingers now.
I had to remove the yoke on rear differential ; is there somthing particular to know when you put it back ?
Does anybody knows which torque it needs ?
Already thanks
Nathan
