Lights not working...
Mk23
81
Port Angeles, WA
So my latest acquisition is an 1123 that needs a bunch of TLC.
So to address the no lights issue, I went looking for 15a in the back of the MLS three lever plug. I was actually confused for a minute, since I couldn't find it. Went around the plug several times, no 15a. So looked up manual, says pin F. Well Pin F is empty! No pin no wire, nothing. So looked up wiring diagrams, it should feed back to PCB Pin F too. But that one was empty too. No cut wires, nothing dangling and all other wires are in tip top shape! Is there another way to wire the 3 lever plug? Why would someone surgically remove 15a?
Now more to it, how do I fix it? Is there a source for female pins for the Cannon plug? How do you add them? 20201025_085450.jpgThank you...
