LMTV and Gov Planets oil sample analysis
shadowrwolf
Tx
iron planet tests are not very good they do not pull the oil from the same places or way every time and you do not know how long its been since it had a oil change best bet is to do a oil change and test it your self after your oilchange
Jwade
Appraiser - Jeff Martin Auctioneer's
11
Fort Worth, TX
The reason you don't always see oil samples should be quite simply if it is not running there is no point in taking the sample. Protocol is for the truck to run for 30 minutes before the sample is taken... Does that always happen? People take shortcuts all the time and quite simply some inspectors are better than others.
tennmogger
556
Greenback, TN
How long have oil sample test results been provided? On what other trucks are they provided? I'd bet GovPlanet takes oil and transmission samples on the FMTV series because they can so easily. Just start the engine and open the engine and transmission test ports to flow a sample. Most likely they do not run the engine for 30 minutes, and probably do not purge the hoses to the test ports before sampling either. (That would mean they would have waste oil to get rid of somehow.) The test is probably run on whatever resided in the test hose, plus a little from the engine/trans.
As for taking a sample from the drain plug on the bottom of the engine or trans, we all know that once the plug is out, it's Niagra Falls under there. Imagine trying to pull a 4 ounce sample and put the plug back in? Better have some big buckets ready. Can't see GovPlanet risking that at all.
How many other military trucks have sampling ports?
BTW, Blackstone test on my Allison showed high copper. Blackstone indicated this could easily be initial wear on bushings and thrust washers and not indicative of a problem.
An earlier comment indicated that high copper and iron in a test would indicate worn clutches. I don't follow that at all. Why?
I am in the group who think the provided test results are mostly useless.
Jwade
11
Fort Worth, TX
They are typically taken on all vehicles, We have taken oil samples since day 1 as we have been doing it for years on the core business side selling Construction equipment. Some inspectors take on non running trucks as well if they do we post it.
Jwade
11
Fort Worth, TX
I will say that I am pretty confident that if we didn't provide them we would hear complaints about that too. So kind of a darned if you do darned if don't situations :p.
shadowrwolf
Tx
the CO and UT locations have been testing the 5 tons as well
tennmogger
556
Greenback, TN
Your feedback is greatly appreciated. I was a little speculative of poor procedures in my post. It's always better to have the sample test compared to not having it.
thanks,
Jwade
11
Fort Worth, TX
thanks,
Its no worries, fact is we are always looking to improve and that is the one of the reasons I got on the site there is no better way to know how we are doing than straight from our customers which seem to ALL be on this great site! So truth be told I always like when you guys call us out for something it either lets me set the record straight on something or use it to improve what or how we do things!
