Rambling Wreck
- 5
- 18
- Woodstock, GA
Absolutely not and that's why I ask questions. Thanks for the good information.Simply put: Do you believe everything the government puts into a press release?.. or the media reports?..
I also noticed that my a1 has an exhaust brake. I don't think your m1094 has one?This goes back to quoting info from the web. Some info is out there to ease bad reps and sell a "newer, better" truck to the public. I only comment on my truck and hate 3rd hand info. I'll wait for a FMTV mechanic to actually say what is what. None of what's in that attached files indicates any major change... a more powerful engine could just be retuning, same with the trans or internal parts were beefed up..? I just wouldn't read anything into a release without documentation to actually spell it out
THE visual things I can say for sure are that there was a new gear selector WTECII to a WTECIII (mine has a II, but believing the factory that my 1996, delivered in '97 truck is a A1) so that isn't a definate change , later trucks had different door latches/handles. Different PDP (power distribution panel) on newer trucks. My new AO doors have different markers than the original ( but old style latches/handles). My truck has some other changes that supposedly makes it a A1 that aren't in the original TMs. I'm not about read more into it. the truck is what it is, and deal with it as such.
OH, Yeah! well, mine has a trans controller!I also noticed that my a1 has an exhaust brake. I don't think your m1094 has one?
Your truck also has a trans oil pan and valve body. LOLOH, Yeah! well, mine has a trans controller!![]()
OK, so you do have a roof over your head![]()
The exhaust brakes are amazing. I had one chirp the tires when It shifted down. Especially in this area going up and down the long mountain roads and not having to use the brakes.I also noticed that my a1 has an exhaust brake. I don't think your m1094 has one?
I think I hear the first born going up for sale.Your truck also has a trans oil pan and valve body. LOL
Many have rolled forward? As in a front flip, the rear of the truck flipping up and over the front? I'm very skeptical that has happened to even one FMTV. What's your source?Hello,
...Many LMTVs have been rolled FORWARD over the cab coming down hill and slowing, as they are front heavy and more than capible to go UP slopes they can't return down...
I haven't looked at the stats on FMTV accidents, but when I have some time I can look up every case of a reported Army accident involving an FMTV. From what I've seen they're pretty safe. I've been in multiple units with many FMTVs and the only accident I've witnessed, read a report on, investigated, or even heard about, involved a Soldier running over something because he didn't have a ground guide. In the same span of time I've witnessed, seen the aftermath, investigated, or written reports on HMMWV accidents, Stryker accidents, HEMTT accidents, etc. so in my little piece of the world, FMTVs seem pretty safe.
Our mechanic was a "field guy" with a service truck when he was with S&S.Seafire,
Your SS mechanic should have no problem sourcing parts for these trucks. He should even already know where to go for everything.
I'd actually would like to talk to him. My conversations and emails with present and past BAE employees has enlighted me to a lot of the FMTV history and thing at the factory in the beginning.
Only a question. Is the payload cap of a LMTV enough? or would a MTV be better?
It's really not that hard to drive a forward control truckAll forward control trucks handle differently than conventional cabs, especially when empty .This is from the small Haflingers, Pinzgauers, LR101 and into the medium duty 2 axle trucks. The lack of weight in the rear makes for a quick and easy way for the rear to easily swap end on downhill, braking and steering maneuvers . Given the same size bed and load capacity, the forward control will be shorter overall and in wheelbase, also changing its road characteristics .
Another characteristics overlooked in the actual driving of a forward control is that the driver is now positioned over or in front of the steering axle and he must wait until he is physically in an intersection before turning, whereas in a conventional cab, the steering axle is in front of the driver and he starts turning the vehicle before he (the driver) has reached the intersection. As minor as this seems, many people have trouble with this and will turn into things, side swiping things.
With over 12 years of driving all kinds of Euro forward controls ( and 40 + including a VW bus) I can tell you that the 4x4 and 6x6 Pinzgauers not only handle differently, but there is even a bigger difference between the 4x4 gas Pinz and Diesel Pinz in which there is a 8” wheelbase difference. The rear axle is even being farther behind the driver and
an offroad line has to be altered for that even. A few times I had kissed a boulder with a rear tire because I was following a gas Pinz and didn’t hold a straight line the couple of inches needed for the rear to be clear.
There is even more differences that cause handling issues that drivers need to be aware of to safely operate the 2 axled forward controls. The 3 axled models are much more stable and a bit more forgiving as far as driving maneuvers
Seafire,
Good luck with the rework. I like the FMTVs, just too many conventional cab drivers that don't understand the forward control and mechanics that have problems grasping a different way of doing something. Fortunately you have a S/S mechanic and you're well ahead in the game.
Other than the damaged done in the landing "malfunction" of my M1094, the rest of the damage was by forklift where they had wood blocked at the middle axle for one fork, the other fork lifted at the front guards tweeking the guards, fuel tank and the tool box. Relativity minor damage. Fortunately, no mechanical damage done.
Cheers
Dave
Before I made my post, I was wondering how long it would take for a Mogger to take offense.It's really not that hard to drive a forward control truck. My Unimog has never wanted to swap ends going down steep hills. Not once and I've gone down some steep hills.
