LMTV cabin fan not working
derpschitz
104
33
Wildwood, FL
The bolts that hold the cabin heater in place are accessed from outside. Remove the grill and you'll see them above the radiator on the cabin floor. To remove the cabin heater you have to dismount the parking brake manifold and knobs, and disconnect the water lines, too. Power runs from the power panel to the back of the heater box.
Removing all the screws, bolts and knobs from the interior cabin facing side does allow you to remove the panels granting access inside the cabin heater box to work on the lights and fan switch.
Good luck—
I did take out all those screws but I can't get the panels to budge. All the controls and stuff are holding it in.
hike
—realizing each day
908
Texas Hill Country
Right. You have to pull the knobs. The three are screwed on to the pull rods. You may need a pair of pliers to hold the rods from turning. The fan control just pulls off and slides back on—
