LMTV Mirror Brackets
Cave Johnson
84
Texas
Anyone else lacking the the upper and lower mirror brackets? (lower shown below). My truck only came with the driver side mirror assembly, so Im replicating it for the passenger end.
Im going to have a set burned out for myself, but I wouldnt mind having more made to dilute the setup cost. (Example, lower bracket one unit will cost about 50, 2 units 35 each, 3 units 30 each, logarithmic decline to 20 each)
I know the actual unit has those dimples pressed in, but cutting them out should function identically, my model shown below.
  • Like
Reactions: HDN
AFGVET
Fort Bragg NC
Why would you not stay original to the design?
What is gained by cutting out the position indentations?
I would think that long term risk is that its another exposed edge where corrosion can start.
  • Like
Reactions: HDN
Cave Johnson
84
Texas
Im making them out of stainless. I also dont have a press big enough, nor a press bit shaped like that, its a very unique tool. The door will be a pile of iron oxide dust before the one Im making will fail.
Side note, that kind of embossing is practical if you are making half a million items. Not 1 or a dozen.
Cave Johnson
84
Texas
Nothing sacrosanct about S&S designs. Trust me on that one. This is what's on the truck from the factory. Someone in the engineering department simply adopted a press tool standard that existed previously and moved to forward. Its probably a little stronger by virtue of work hardening of the steel and non-removal of material, but that was not a consideration when this was thrown together. It was the cost to manufacture half a million of more of them, at which point saving 10 cents per unit adds up.
HDN
4,889
Finger Lakes Region, NY
I'm curious - what CAD program are you using to design this part?
It's stuff like this that's great for making stuff that otherwise costs and arm and a leg to get NOS!
