Ronmar
- 8,369
- 113
- Port angeles wa
24v at the solenoid = fan OFF. No voltage at the solenoid = fan ON.. so when you unplug the sensor the power at the solenoid should disappear, which wpuld be perfectly normal.
It is also normal for the solenoid to energize when you turn on the ign switch and to de-energize and vent air every time you turn off the ign switch.
Does your solenoid even go "click"?
You could hook up a test light or a relay to the solenoid wires to insure the circuit is capable of delivering enough current to energize the solenoid...
