Long weekend multifuel swap
JasonS
144
Eastern SD
I traded labor and a snow plow for a good deal on an LDT-465-1C engine and radiator and swapped it for my 400 Reo this weekend. The multi is a MUCH tighter fit than the gas engine. Operating in the same RPM range, pretty close to the 400 gas. Hoping to increase it a bit with more fuel and maybe the LDS-427 turbo. Whistling turbo aside, engine/ drivetrain noise seems very similar. Part of that may be due to a noisy tranny begind the gas engine. Still have a lot of plumbing and electrical to finish out.
The multi's hood side covers don't fit right. They need to fit further forward than they do; anybody who has done this swap have any ideas?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Did you change the grill? They are different. Want to get rid of the gasser radiator?
JasonS
144
Eastern SD
:shock:
Why do you get rid of the REO?
Several things led to this but basically I wanted to try something different and I got a line on everything to do the swap (engine/ tranny/ radiator, and all the bits and pieces) for a price that I could justify.
The 400 Reo worked flawlessly and will give new life to a Farmall F20.
JasonS
144
Eastern SD
I changed the grill to a multi variant. It seems like the hinges are slightly further aft on the gas truck. I'd hate to start modifying things if there is something obvious that I am missing.
I plan to keep the radiator to use with the farm tractor repower. It is a strange version with the upper support tied to the tank and not the frame of the radiator.
NDT
6,500
Camp Wood/LC, TX
What is this Reo 400 you mention? Is this some kind of bigger inline 6 than the usual Gold Comet 331?
