Looking for info on the fill pipe for the master cylinder
PaFarmer
35
PA
I am planning to put a remote reservoir on my brake system If I can’t find a fill pipe. I rigged up the same on my M35A2. My M211 does not have a fill pipe on the master cylinder. The cap for the master has 1.25” threads and no shoulder, so it can be run in too far and drops into the master cylinder. I had a spare master cylinder cap for an M35A2 so I used it, but I would like to install the fill pipe or use a 1.25” threaded pipe as the extension, but need the correct thread pitch. Any pics of an original, leads on an original or know the proper thread pitch?
PaFarmer
35
PA
JUst make one
As I said in the first post, I put a remove reservoir on my M35A2, that wasn’t the question. USMC 00-08 posted the pic I asked for. Id like an extension, if I can get one. If not I have the reservoir bottle and hose ready to go.
USMC 00-08
179
Skiatook, OK
I got the pieces broke loose with a little help holding it. They've been together a while.
I think they will clean up fine if you have a way to bead blast it or can wire wheel it inside and out. Let me know if you want to mess with this..
20201001_153704.jpg20201001_153657.jpg20201001_153707.jpg20201001_153716.jpg20201001_153722.jpg
lucydeuce
13
Cogar, Oklahoma
That's cool. I've never seen that extension filler pipe before. Does it put the cap right at the floor pan, or just under the hatch?
Yes mine is that way puts it about a quarter inch below the hatch in floor took me forever to figure out where to put brake fluid when i got the truck home all i could see was the banjo bolt and brake hose. made my wife work brake pedal and i followed the linkage to the master cylinder
