Sephirothq
- 26
- 48
- Trevorton / PA
I am looking on northern tool's website for some parts. There is a hydraulic tank that would work fine. I think the stock system is about 42 quarts?
So i should have at least a 10 gal tank. I assume since the pump is always turning the extra oil is there for cool mass. So that is the tank.
NorthStar Steel Hydraulic Oil Tank — 10 Gallon | Tanks + Reservoirs | Northern Tool + Equipment
I am not an expert in hydraulics but i know the system needs a pressure releif valve as a safety.
Prince Adjustable Relief Valve, 3/4in. | Relief Valves | Northern Tool + Equipment
So that is the safety valve.
I got a pump that bolts to the Cat engine. It makes 13 GPM at 1000 RPM, 3500 max PSI and it has 1" ports on it.
I am looking at the following control valves I am looking for input. I know they are 12 volt solenoids, but it shouldn't put that many amps to worry about it that often.
Which valve am i looking for.
Northman Fluid Power Hydraulic Directional Control Valve – 26.4 GPM, 4500 PSI, 3-Position, Double Solenoid, Tandem Center Spool, 12 Volt DC Solenoids, Model# SWH-G03-C6-D12-10 | Power Solenoid | Northern Tool + Equipment
or
Northman Fluid Power Hydraulic Directional Control Valve – 26.4 GPM, 4500 PSI, 3-Position, Double Solenoid, Open Center Spool, 12 Volt DC Solenoids, Model# SWH-G03-C3-D12-10 | Power Solenoid | Northern Tool + Equipment
or
Northman Fluid Power Hydraulic Directional Control Valve – 26.4 GPM, 4500 PSI, 3-Position, Double Solenoid, Closed Center Spool, 12 Volt DC Solenoids, Model# SWH-G03-C2-D12-10 | Power Solenoid | Northern Tool + Equipment
or
Northman Fluid Power Hydraulic Directional Control Valve – 26.4 GPM, 4500 PSI, 3-Position, Double Solenoid, Float Center Spool, 12 Volt DC Solenoids, Model# SWH-G03-C4-D12-10 | Power Solenoid | Northern Tool + Equipment
or
Northman Fluid Power Hydraulic Directional Control Valve – 26.4 GPM, 4500 PSI, 2-Position, Spring Offset, 12 Volt DC Solenoid, Model# SWH-G03-B2-D12-10 | Power Solenoid | Northern Tool + Equipment
or
or
or
or
