BigjeepTX
- 2
- 0
- Mckinney, TX
Good luck with your search. I want one in North Texas if anyone has a good deal on a M35A2.
If it is then it locks front tandem and rear tandem together, not side to side. With a Mack at low speeds the front tandem will spin on one side and the rear will spin on the opposite side; so you have power to both sides of the truck, but only one axle each.I thought M35's were set up like MACK Diffs. The peanuts in a MACK Diff. work like a governor, and lock at low speed, unlock at high speed.
Where you intend to drive it, lockers will be a waste of money. And they are NOT cheap. Also, as said, the deuce engine doesn't have enough HP to turn 6 wheels.
