- 8,698
- 3,205
- 113
- Monrovia, Ca.
Banshee365, Get the tester. It could be as simple as an upper radiator hose leaking past a clamp and running down the core. Maybe the cap is weak or missing all or part of the seal and, since the overflow pipe is out of the neck, coolant is running out of that and down the radiator. It would be a time saver if it were one of these problems and you DIDN'T need to take the radiator out.
