dependable
- 187
- 63
- Tisbury, Massachusetts
Not only do you want a J code pump, but the actual model number for your truck. There is some interchangeability, but there are several different model applications for a DB2 IP in the 6.2. Not sure what original CUCV pump was, but I believe the DB2 4544 is what I put in one of mine, and it seems fine.
There are some differences in fuel volume and timing, manual vs auto transmission, etc. A good injector shop should be aware of this though, so if they know what truck it is going in , should be OK.
I tried to link to chart of DB2 pump numbers linked to older thread here, but seems it does not work anymore. I'm sure it is out there somewhere though.
