Hi There , time for a update.
I have removed the tank cleaned it, removed the outside rust painted it with hammerrite, cleaned/repaired the tank filter who was fallen apart endfilter was lose and the valve was stuck with diesel flakes , replaced the fine fuelfilter. in the mean time replaced the rear U-Bolts who where halve of what they were, replaced a front brake disc repaired the callipers, killed my main brake cilinder during bleeding, BUT the encine problem still is there . the engine will not idel in P or N you have to push the pedal , some times when you push the trothel it wil increase rpm's , when go in D it will move but no speed, when hit the brake the engine stops. yesterday i made a test drive a round the vilage first it drove a littel than i stopped the car for a short period, fired it up again.
But the m1008 wouldend go Forward or revers, after many try's i switched in to 4weel L and made it home with a Max speed of 3mls a houer .
I have tried a lot but dont know where to look now....
