Low air pressure buzzer is dead.
tractorpuller1
Quakertown, Pa.
My truck runs great, but the air pressure buzzer is now dead. It went from going off all the time, to going off some of the time, now it is dead. Air pressure is fine and builds fast. Where do I look? How do I replace it? Are parts still available for this?:-?
1,123
Sounds like your truck is never running out of air. I'd consider it a blessing. :D
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
if its the buzzer itself, it is under the dash just to the right of center, its a box about 5inchs square, i just pulled one off a parts truck if your interested pm me.
m16ty
210
Dickson,TN
You should be thankful :wink:. The first thing I do to a truck I'm going to keep is unplug that thing. I know you should use them but I like to hear how the engine is running when I fire it up and not a loud buzzing in my ear.
tractorpuller1
Quakertown, Pa.
I know it's annoying but I need it to work for inspection. My truck holds air pressure for about 8 hrs after shut down if I don''t release it first. I will check under the dash tomorrow. Thanks!:-D
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
so why not just turn the acc switch off till enough air pressure is built? that way you keep the safety of knowing if you lose to much air?
Katahdin
23
Scarborough, ME
I suggest checking the wires/connector behind the dash if you haven't already done so. Maybe its just loose.
Lately on my M109A3 I've actually been pressurizing the system from my 'shop compressor' before I start it to avoid hearing the buzzer. I'm doing this so I can listen to the starter engage the flywheel since I've been having some intermittent starter issues.
I pressurize the system using a quick connect under the dash with a a male-to-ball_valve-to-male connector between the dash and my shop air hose. Its also handy to look and listen for leaks while the engine isn't running.
tractorpuller1
Quakertown, Pa.
That is a great idea. I can easily do that at my shop. I have the female coupler on the inside firewall anyway.
I did check the wires. I can find nothing wrong. There must be a pressure switch some where. Can that be the problem? :roll:
Katahdin
23
Scarborough, ME
Yep, there's a pressure switch. (I had to look it up myself)
See TM 9-2320-361-20 page 2-132 and 2-133 for the electrical troubleshooting procedure and diagram.
mckeeranger
Eastern Kentucky
Ours died when I had a battery connection problem. (M35A2) The alternator went into some major over voltage and fried it. We also lost a few bulbs.
The one on the XM817 has never worked, but I was told at the last inspection I had to fix it, even though the truck is air assist, not actual air brakes. Inspection is not required on the M35, it's too little. :-?
1,123
I take all the buzzers out of my trucks. If it went dead GREAT! less work to disconnect it.
And the new owners say "What a junker!" when they get them home.
1,168
I can tell you from experience, I wish the low air buzzer had worked when I was driving someone elses 5 ton wrecker through a small town intersection, and there was no air( an airline had broken), which also meant no horn! No way I was gonna stop(was traveling less than 30 mph).
Don't disconnect your buzzer. Fix it if it does not work properly. You may save your own life or mine.
That day, I was just plain lucky. 2cents.
Westy, I'll demote you, if you don't reconnect your buzzer! Love DH
Snarky
9
Brazosport, TX
I had what turned out to be a copper tube from the top of my compressor break off while driving home one day. I assume it has something to do with kicking it on and off using air pressure, because when it broke my buzzer sounded intermittently when you hit the brakes, even though it was still building around 60 PSI.
Needless to say I was white knuckled on the few blocks home, with no real place to pull over and check the air system. I'll tell you what though: that buzzer works, when ever your hear it, your eyes magnetically lock to that air gauge.
Pinz25086
31
Orlando Fl.
Why not add the low air pressure idiot light to the dash and not worry about the buzzer? The light kit can be found on e-bay most of the time for less than $15 and then you will have some indication of a problem without all of the noise. I believe that you need to have some kind of warning device to be legal with the DOT (at least here in FL).
Wayne
Westech
CPL
6,104
206
cow farts, Wisconsin
I dont like the buzzer. I do a gauge sweep every 15 seconds or so like the "book" tells you do to. I will be hooking up a light to the switch so a light will go on but the buzzer... is History.
1,168
:evil: Westech, your about to be a 3 star, soon.
