Low Air Pressure Troubleshooting
kymike
Milton, KY
Just removed the dryer assy; no data plate. There are two numbers stamped into the dryer assembly cast body; one looks to be a part number N4250B so I assume the other number might be a serial number.
welldigger
17
Benton LA
Your unit should be the haldex pure air plus. If I remember correctly there are only 2 kits available. Check Erik's military surplus. He has the 2 kits listed and the serial number range they apply to. It will also give you a price to reference.
kymike
Milton, KY
Once again I want to thank everyone for their advice. Got all air leaks fixed. I ordered a NAPA DQ6020 lower repair kit and a NAPA DQ6026 upper repair kit for the Air Dryer/Purge Valve. The rebuilt job took me about an hour and everything worked at the end. Thanks again.
