- 2,321
- 4,168
- 113
- Pepperell, Massachusetts
Yup, yours is set to 416
kinda what i figured.The GFI is only for the 120 volt outlet.
The wire is TGGT (Teflon/glass/glass/teflon, aka tape/glass/glass/tape) high temperature wire, rated 250-300C (480-575F), typically white or tan like this;ok so i cleaned up the rats nest. the wires directly under it are unharmed. other wires have insulation chewed off but the wires are intact. I put liquid tape on them for now. wondering if i should fine the right wire and replace them but have to source the wire first.
Started it up checked voltages and of course today it decides to work. Moved wires around while running and everything stays proper voltages.
seems im a newbe and being so cant post a classified add.What you may also do, is see if someone has parted out a MEP-813A (400 hertz model), and would send you/ sell you the wire harness. Start a "Parts Wanted" thread. Most people think of the as junk after they loot out the engine and a few other parts. They forget that the wire harness is ALMOST the same.
