Lower dual pintle hitch converted to receiver style
Coondawg
Florida Panhandle
My Deuce served lastly as an Air Force truck. It has dual pintle hitches on the back. I suppose the lower one was for lower profile trailers, power units, AC units or something of that nature. I know there are several receiver hitch threads floating around, but none seem to show anyone with dual pintles. I'm almost done bobbing it, and I thought it would be slick to remove the lower pintle hitch from the bracket, and fab up a receiver tube in its place. I thought of welding a colar around the tube front and back of the bracket, and also weld in some horizontal support behind it. There are 5-1/2" grade 8 bolts that attach the bracket to the frame. Has anybody done something similar to theirs? Does anyone have a better suggestion? I tried searching this, as dual pintle, two pintle, 2 pintle, Air Force pintle, but didn't get many results. I don't even know what this setup is officially called. Didn't find much in the TM's either. Thanks, Coon
gimpyrobb
dumpsterlandingfromorbit!
27,786
769
Cincy Ohio
Wow, that is quite the field modification. If I were you, I would just find a class 5 hitch and bolt/weld it on the deuce's frame. That way, when you are not pulling a trailer, you can pull the hitch and have better gound clearance. It might not be important to you, but for us that go off road, it is.
Coondawg
Florida Panhandle
Good suggestion, I hadn't thought of the clearance issue. Technically, I could still unbolt it, but it is quite heavy compaired to the standard class 5 hitch. Thanks.
goldneagle
1,203
Slidell, LA
You can buy a Class 5 hitch on Amazon.com that is already set to the 34" frame spread. I did that on my M109A2. The bolt holes centered on the frame. 6 holes later I had the hitch installed. It is included in my thread on my M109 Restore project.
Coondawg
Florida Panhandle
I've been looking at those trying to decide which way to go. I believe the Curt 15530 is a common one used. I'm sure that's easier than what I proposed.
