Lug nut OD size m1009
tbearatkin
24
SouthWestTennessee
Just FYI if missing your tire iron the correct size socket for the lug nuts on a M1009 is 19mm. 3/4 fits but is loose. 19mm was a snug perfect fit.
I searched for this for an hour on here but could not find the answer I needed
Keith_J
1,314
Schertz TX
I too discovered this. Also, a 22 mm fits on the 1008/1010/1028/1031 singles. I thought it was 7/8" but 22mm is a better fit.
Thankfully I have a full set of metric impact sockets.
GREENMV
Linden, TN
Never thought about Metric. I have been using 3/4" I will try next time I pull my spacers. aua
Keith_J
1,314
Schertz TX
When you get over about 18mm, most metrics have a decent fit in 6 point sockets. 19 mm is 0.74803", give or take. Less than a sheet of paper difference.
