RE: Alive
The break cylinder was empty. So I had to add brake fluid, I don’t think any brake fluid was in the lines because the brake pedal went to the floor. I’m thinking that once I bleed the breaks with fresh fluid I should be ok? I’m also going to drain the transfer case. Also should I be using any special fluids? Break, transfer antifreeze also what should I use for oil. Any suggestion on color, I was going to use a primer for now to clean up the jeep. Was thinking about Red and black? What is the name of the military green color that should be on it?
