blackhueys
- -9
- 18
- mn
Ok found a cheap fix for those of us that are missing the rubber plug that is in the topper part of M1009 trucks the hole where the antenna cable goes through. My fix was under a buck and here it is, go to your local hardware store and get a 7/8 rubber furniture foot pad thingy like this (see pic) also used on crutches for the foot part. I went to ace hardware my self. You will need to cut or drill a small hole in the middle for your cable if you have one other wise just put a dab of silicon around the edge of the plug and put it in the hole!
