The mechanical 6.5 pump can put out more fuel than a 6.2 pump... only really matters if you are putting a turbo on.JohnFire said:is the 6.5L injection pump a better pump than the 6.2L?
That's the same reason I want to change my IP. I am only getting around15mpg and it is slow when taking off, even slower with a trailer. Also, the exhaust is smoking, a typical sign of a worn IP.One of the reasons I am doing the pump in the first place since I used to get 20+mpg now it is less than 16mpg.
Thanks for the tip. That's all I needed was an idea of where to shop around for one. I would have posted in the want ads but I'd like to get a pump ASAP.Mike, go to a shop and get one.
If you want one on a shelf somewhere call saturn surplus. I have a spare and am hording it.
Try posting a WANT ad in the classifieds section
K10A: Why don't you go **** yourself.someone call a wahmbulance.... sheesh...
