M1009 or regular blazer?
Warthog
242
OKC, OK
When they started making the 1988 trucks, they where still making the "squarebody" trucks for the 1-ton, suburban and full size blazer. They used the "V" designation for the 4x4 versions.
So the truck is not a true CUCV but could still be issued to the military for support services.
11Echo
96
CT W. R.
There were no C/K trucks in 1987. The squarebody trucks switched to R/V in 1987 through 1991. The new light truck platform took the C/K designation in 1988.
SandBar
Full Time Patriot
763
245
GA/FL
Ok I am so confused. I just got off the phone and the guy message me a pic of the engine bay and it has TWO BATTERIES. If it isn't a M1009 is it a military vehicle? He said no data plate on the inside of the door but the door panels have been replaced (I can see that from the one inside pic I posted earlier). So , all in all what are the chances of it really being a military vehicle, and is it worth 1100?
1,824
All GM diesels had 2 batteries. Are both batteries on the right side? The V settles the fact that it's not a CUCV. Dual batts were also an option on gassers.
11Echo
96
CT W. R.
Does it have 2 alternators?
Anubis8472
Redford, Michigan
It sure looks like a civy K-5 with some CUCV parts.
Drivers seat looks straight out of a CUCV, but the passenger's is civy.
Body panels are civy (could be replacements), no radio bracket holes etc.
No dash cut-out.
As mentioned it is possible it was purchased and used by uncle sam, but it doesn't look like a CUCV contract vehicle.
Have you checked the transmission?
If it's a running 6.2 with a working trans (likely a 700r4) it may be worth a good portion of that 1100 for parts at least.
(Of course, it all depends on how much of your wallet that represents)
11Echo
96
CT W. R.
No dash cut-out.
Standard equipment in civilian 1987 K5 with the diesel engine was the 4 speed automatic/overdrive.
If it runs good offer him $600 and go from there for it as parts vehicle. Likely to have either 3.42 or 3.73 gears also.
Skinny
495
Portsmouth, NH
I think all Civy Blazers of that era with a 6.2 diesel should have a 700r4 not a th400. If someone ordered a half ton vehicle, I think it should of had a th350, not the th400.
SandBar
Full Time Patriot
763
245
GA/FL
I learned lots of good info. He said that black thing by the shifter is a mount the military used for their radios. Also said that plug to the left of the glove compartment is factory. If I get him to 600 maybe it is worth it since it has most of the same base components. I noted the dash did not have a [D] just normal D (no overdrive I imagine). I checked my phone again and both batteries are on the right hand side and yes it has two alternators.
Varyag
Garfield, Washington
It looks like the Forrest Service k5 a friend of mine has. It has just way too many civi parts to be military and someone already confirmed that the vin was civi.
It looks like a lot of work. My advice would be to walk away.
SandBar
Full Time Patriot
763
245
GA/FL
Offered him $400.00 and he said yes, sounds like I got good spare parts for an ok price. Will get it home tomorrow and dig in.
richingalveston
122
galveston/Texas
$400 you get the parts and your money back
For that price you can get all the parts, including engine tranny and axles and still get $400 at the scales. I just got $600 for the 87 burb I stripped to nothing, just the shell frame and rear axle without the doors or glass and I got $600 for it.
$16.00 per hundred pounds your junk yard guy just lost money.
Bad for him and good for you.
Good luck with it.
SandBar
Full Time Patriot
763
245
GA/FL
Thats a steal
Any reason not to fix it up and drive it as is?
I may, I really have my heart set on a real military vehicle. If I can sell/part it at a profit it helps the deuce fund. I guess I will decide once I really go through it tomorrow.
1,824
I think I speak for the lot of us here but I'd really like to see lots more pics of this truck. It's always intriguing to figure out just what was put together. $400 was a bargain and half again that price.
SandBar
Full Time Patriot
763
245
GA/FL
I will certainly post pics. If it turns out to be a real green beast at its core I may well keep it. My main reason to get a CUCV is I own 0 diesel vehicles (just the mep generators), and a deuce is still a bit out of budget. My RAM 25000 is a great truck but mpg sucks and military diesels are excellent SHTF vehicles (and coooool).
If I keep it I need to find someone to sell me a CUCV grill, bumper and some other parts.
