M1009 starter issues
rust4days
Staten island N.Y.
I could use some ideas I replaced my starter and the same exact thing happened 2x my battery cables got real hot and melted themselves to the battery post and starter cooks, could a sticking starter relay do this?
phil2968
17
Lakeland, Florida
We need more info. Is the system stock 24volt or converted to 12? Where did you get the starter? Is it 12 or 24? Why did you replace the starter? You said "the same thing happened again". Is your engine locked up?
rust4days
Staten island N.Y.
It is a 24 volt system the engine is free runs fun the starter was rebuilt for 24volts I had it replaced when I replaced my fuel injection pump. Getting all the air out of the system destroyed the 1st starter since then I fried two starters and I noticed cables or really hot and arched to the point where they welded themselves to the battery post ,at this point only thing I can think of is replace my relay and big cable to starter everything is fine and functions as it should, oh one more thong it's always the secondary battery that receives arcing from the starter
rust4days
Staten island N.Y.
Ok so I figured it all out my starter relay was faulty and my starter was getting stuck on the fly wheel it needed a shim and my terminals on my battery cables where crappy they where not allowing full voltage to travel to the starter so they began arcing causing my battery posts to melt the lead off and also my positive cable want very reassuring either I will also replace the ignition starter wire too cause it prob seen better days
rust4days
Staten island N.Y.
I cranked it over it started fine then shut it off tried again and my clamps smoked and cables got stupid hot and starter just clicks it's making me mad lol I'm just going to start replacing all my starter and ignition wiring
porkysplace
1,487
mid- michigan
I would replace the cables they could be corroded in the middle or damaged from the heat . Make sure the ground to the block is clean including the threads for the bolt . Have you measured the resistance of the cables ?
By the way your posts are hard to understand without making sentences and breaking up what your trying to say.
rust4days
Staten island N.Y.
I'll try replacing the cables first, I did not how ever measure resistance, but I have spare cables I will just replace them! As for my broken sentences I'll try to complete them
1,170
Finish them with punctuation(as the rules request).
We have high standards on SS, so up yours.
rust4days
Staten island N.Y.
It was joke Mr serious, you guys are to serious for me, I'm an older person with fun in my bones thought I'd join this site cause I had a common interest in military vehicles but there's plenty of other sites I can go to if I'm too much fun. Sorry if any one got upset y'all have fun with out me
1,170
I was attempting to be humorous as well.
