broknindarkagain
- 0
- 0
- Phoenix, Arizona
Hi guys,
To start off with, I have a M1009. It is all original with the exception of being converted to 12 volts (didn't want to do that but couldn't find a 24v starter. Had to use civilian 12v starter).
ABRIDGED VERSION : I need the proper throttle cable for my M1009. Read below for all the details. GM part number 14038644 crosses over to Pioneer CA8503 and does not fit properly
Last week I was having an issue of my throttle sticking. I would push the throttle and it was stay engaged almost acting like cruise control (or if I pushed it harder it would just keep going faster and faster LOL). I looked over things and the only thing that seemed kind of funny was the throttle return spring felt weak to me. So I went to ACE and found a spring to put inside my original spring. It worked absolutely great for a week....felt as it should and throttle returned to idle quickly when I let go of the gas.
I'm afraid that may have been the beginning of the end though.
This morning my wife drove it to work....or at least tried to drive it to work. She got a few miles from the house and while merging onto the highway the throttle pedal just "went dead" as she put it. It would just fall to the floor.
Now my first though was that it had come off the injection pump because this has happened several times. The e-clip that holds the "eye" on the end of the cable to the pump is missing so I had a zip tie there to hold it on.
I got a lift from a friend to where my wife was. The cable on both the pedal and injection pump side was still attached...but the pedal did nothing. I wound up pulling the cable out (just the metal inside cable) into the cab. Broken cable. Looked clean and almost brand new on the inside, but it was frayed and broken close to the bracket above the injection pump. My friend wound up tow chaining me and the CUCV back to my house where I could safely work on it (I'm not wrenching on the side of a highway).
I originally called Autozone and asked for a throttle cable for an 84 diesel K5. The cable was too short.....WAY too short. I did some searching and found on this forum in another thread that the OEM part number is 14038644. I called Auto O'Reilly Auto Parts and had them cross the OEM number over and wound up coming up as a Pioneer CA8503. I removed the entire broken cable from my truck (plastic tube thingy that holds the metal cable) and took it with me to O'Reilly so I could compare the cables. Length seemed good but the "eye" on the injection pump side of the cable was MUCH smaller. I figured there use to be a plastic bushing in the original one that rotted away and that is why it was so big. The new cable didn't have a bushing.
I got back home with the new cable and started to install it. First thing I noticed was that where it clips into the firewall - the new cable was a bit too small on that clip so it wouldn't snap in. It just kind of sits there and bounces around that square hole. I figured "eh screw it. As long as the rest works that won't be a big deal". The cable attached to the throttle pedal is it should so I moved on to the injection pump side. The cable is about an inch too short! When it is hooked up to the injection pump my truck will idle at 3k RPM because the cable being to short to return to idle. Also, the "eye" on the end of the cable didn't quite fit all the way onto the injection pump anyways. It was a hair too small. It wouldn't go past the groove that the e-clip sits in.
I wound up having to use wire to loop around the injection pump and up through the eye on the cable to get the extra inch I needed. It is ghetto rigged but it works for now.
Anyways - I need a proper cable. One that will actually fit properly and I also need the e-clip so the cable doesn't fall off anymore. Does anyone have a source for the PROPER cable that is a direct fit on the M1009? I'm about to pull my hair out. I really need something that is local and I can pick up from the parts house....even if it special order. Part numbers or whatever would be a big help. Or if anyone knows a workaround. The cable I got, its compatibility listing has every vehicle that had the 6.2 in it.....so I'm not able to find any other cables that are listed for the 6.2....only one option.
Ideas? Thoughts? Suggestions? I'm at a dead end here and can't figure this out. I just need to be pointed in the right direction. Sorry for writing a novel lol. I'm frustrated and needed to vent. My two daily drivers cars are broke down needing major repairs, so my wife and I are stuck sharing the M1009. I need to fixed ASAP. Fixing a throttle cable is a little easier on the wallet than rebuilding a transmission in one car and buying all the timing components in the other car.
Thank you ahead of time for anyone that has any answers.
