quickfarms
- 22
- 38
- Orange Junction, CA
I had thought about it years ago but I found that if the trailer is evenly loaded it is quite well balanced and dumps very easily. I use a 6 foot digging bar for leverage. I run it through one of the front shackles and put the tip between the spring and the front hanger by the pivot point.If you develop / design a hydraulic dumping system for these trailers, please post it. I'd be very interested in that modification, and I'm sure others on here would be as well.
Thanks,
Storm 51
I just unhook and tip mine. Works fine. If I need the help, that's why I have my farm jack permanently bolted to the side.I had thought about it years ago but I found that if the trailer is evenly loaded it is quite well balanced and dumps very easily. I use a 6 foot digging bar for leverage.
The trailer looks like a M101A1 no surge brakes.Did you ever put a flexible brake line on the trailer or did you not bother with it? I figured you removed the wire harness clips with it tilted that much.
Ahhh! I put an A2 surge brake on my M101 trailer, I keep forgetting other folks don't have that!The trailer looks like a M101A1 no surge brakes.
Agreed..... but.....The wet blanket only dampens my perspective of the usefulness of this site, when you search for some info, and every thread on the topic has the same wet blanket killing the thread, it gets old.
The heim joints are not the weakest link structurally and they are rated for 9,800 lbs each.Not trying to be a jerk, but the way those eyelets allow the pins to move around a bit, and the way those heim-joint are oriented - that's a bad combo. Looks unsafe. Would be much better/stronger if you made some simple brackets to re-orient the heim-joints so they'd be inline with the trailer tongue. Again, only trying to be helpful.
