stevoMT
- 0
- 1
- Colstrip/Montana
Classic.mounted mine to front grille guard
This inspired me. If you use the patient crane to lift, it occurs to me that you could mount a receiver hitch vertically behind the rear towing shackle. Fabricate a ~30" vertical "stick" to insert into that receiver, and mount tire to that stick. Use a standard (locking?) hitch pin to secure the stick to the receiver. Use the patient lift crane to raise and lower tire/stick, either by unbolting the tire from the stick, or pulling the hitch pin and pulling the stick and tire out together. When parked, you can pull the stick and tire so both doors are available to open all the way. Just stash the stick & spare on the ground under the truck until it’s time to pack up and leave.View attachment 459004
Finished up the rack. Seems to work alright, no issues with deflection or anything. I made a simple fork to flip over and hold it in the open position so it doesn't swing closed when your on a hill.
I have not even tried yet. Item 642 on the "to do" listRecovery 4x4, did you ever get the 255/85/16 to fit in the stock spare carrier? Thank you!
Read through this thread and thought OH SHOOT! The full size spare 37" won't fit!? I did not buy a set of 5 when I got this size but I planned on it fitting without issue under there, I will see if I can get under there soon and test fit this size I have a set of coopers ... Something tells me that might be too easy :/Recovery 4x4, did you ever get the 255/85/16 to fit in the stock spare carrier? Thank you!
