M101A2 Master Cylinder Cap Vent
1956_4x4
Crestview, Florida
The cap on my master cylinder has a threaded hole in the center of the top. There was a deteriorated piece of plastic in the hole when I picked the trailer up from GL.
What should have been in the hole to prevent water from getting in the reservoir? I know I have changed a lot of these master cylinders when I was in the military, but I just can't remember what was used to keep water out of the brake fluid.
Smitty
1,814
Some caps and a sheetmetal cover over them. I had a few that had a small steel line shaped as a J with a piece of rubber hose to extend it. I'm working on modding a cap so I can run my brake bleeder on the trailer!
KsM715
142
St George Ks
Nice find. I looked through their website but couldnt find what I was looking for. I plan to call them monday to see if this part can be sold separately.
This would make selling a trailer much easier.
Sorry Smitty hope you dont mind me hi-jacking your thread.
86m1028
Murphy TEXAS
I have had both also, & have also noticed they are different size vent holes.
lindyp38
ulster county ny
any luck with the cap question...
can u just get match up another cap...or does it have to be vented......my other m101 doesnt have this vented type cap.....
thanks
1956_4x4
Crestview, Florida
The cap in the master cylinder needs to be vented. Some have a hose and some have a small hole. The replacement master cylinder came with the cap with the small hole. I'm going to use it with a sheet metal cover over the entire unit. Because of the fluid being open to the outside air, mine will be a silicone brake fluid vehicle.
Smitty
scrapdaddy
11
Dittmer, Mo.
Why can't you just drill and tap for a nipple and hose or some arangement of your own design, just to vent, no big deal.
goodguyzy
13
medford oregon
I just picked up another m101a2 with a rusted cap, wont a deuce cap fit it? Ive got a spare Im going to try out. My first one was just rebuilt by uncle same with that same huge hose.
rfischba1
Fort Meade MD
My M101A2 also had a vent cap that was rusted out and allowed water to get into the brake fluid , its now a mess with debris in there. Whats the best way to clean a take out?
rosco
Delta Junction, Alaska
A complete re-fit of the hydrolic system. Take the master cylinder off and clean it with brake clean and rinse it with alcahol. Put a kit in it. Blow the brake lines out, re -do the brake cylinders. That is probably not what you wanted to hear, but you can't clean it any other way. Its probably rusted up now anyway, and not working!
