M1028 front axle additive
Skinny
486
Portsmouth, NH
Pretty much all GL5 gear oil will be rated for limited slip diffs. Of course I would not rely on that working good if you buy cheapo oil. The safest bet is swing by a Ford dealer and pick some up if your parts store doesn't stock a seperate additive. The only reason I say Ford is that most of there limited slips are clutch types so they carry the additive. GM has a lot of mechanical style diffs and Chrysler has changed to gear drives on some trucks Ford has the highest probability of stocking it and the parts guy actually knowing what it is. Should come in a small bottle.
