M1028a3?
2deuce
154
portland, oregon
The brace in the rear corners prevents the tie down loop from twisting. My truck had make-shift anchors in the corners. I had a Marine Corp M1028 that had make-shift bed rails, that I think were used instead of dunnage. I have seen pictures of shelters in CUCV's without dunnage, and the shelter resting on the bed. So there doesn't seem to be hard fast rules.
Did these Dana 70HD dually's have a posi unit in them? Without removing the cover, is there a way to tell? I had a Dana 70HD in a 79 ford 350 with a posi and it didn't work as far as I could tell. Once I parked it on an incline with one wheel in the wet grass and it couldn't move. I took it back to the dealer and they only tried to blow some smoke up there. Far as I know it never worked.
I have heard that front posi unit is often removed from the Dana 60 on a M1028. Was this common? If so why, and which branch of the service was more likely to do it? Thanks
CUCVFAN
Gunner's Mate First Class
47
Jarrettsville, MD
I will say that I *suspect* there are not likely any factory versions, but I don't deal in certainties with these things anymore. Many people think that all M1028A1's were conversions, but I have a pic of a factory dataplate showing otherwise. I've not yet seen any factory pics of either an M1028A2 nor A3 dataplate.
Here's some more pics from the surplus dually conversion kit I bought years ago. It included everything for the conversion, including the side mirrors, which are specific to dually versions (convex on passenger, extended arm on drivers).
2deuce
154
portland, oregon
I'm going to have to test mine to see if both wheels will spin. I had both rear wheels up in the air a week or so ago. If I spun one the other side would go in the opposite direction. I thought that meant it was open. Is that inconclusive?
CUCVFAN
47
Jarrettsville, MD
No, unfortunately that is pretty conclusive that it is open.
2deuce
154
portland, oregon
That is what I always thought. Probably the front is open too. I can't imagine having the front without the rear. Looks like I will be in the market for one, if not both. Thanks
