Skinny
- 488
- 83
- Portsmouth, NH
I am fixing my generator setup on the M1031. My truck came with no linkage between the actuator motor and the little heim joint that attaches to the IP throttle assembly.
I fabbed up a temporary rod to see if the system works. It works well but I noticed that the throttle pedal is no incredible stiff to push on (almost feels like something is going to break) and the actuator limits the throttle movement to about a 1/3 of what it should be.
I'm not sure if the linkage is suppose to be a solid rod or maybe a pushrod that doesn't tug on the actuator when the pedal is pushed during normal driving.
Any help, photos, or someone with a spare rod would be greatly appreciated.
Thanks, Skinny
Thanks, Skinny
