M105a3 Sleeping Corridor
Lextreme
SGV Ca.
I use two heavy duty hinges on the back and 8 ton air jack to open. It should only open the top about 45 degrees.
Lextreme
SGV Ca.
To me popup is alot easier mechanically. It has two hinges and work just like a door opening upward. Lowering and raising would require 4 shocks or air jack. This setup only require one. Alot less mechanical issues like synching all foour shocks.
Blendmaster2002
74
Hesperia, California
I agree with 59apache, no one should be able to lock it from the out side when somones in there! Same goes for the truck, I was looking at my m185 the other day which I have stuff stored in and locked up, and thought how if I ever used for camping or rv I would change the way it locks so some body couldnt just come along an lock me in while sleeping.
Lextreme
SGV Ca.
Oh... no worry it is lock safe. People can not lock us in. There are locks inside and outside...
Lextreme
SGV Ca.
Finally got the trailer painted but still need to do the interior and the air jack installation. It is about 50% done. I will also need to do some pre-wiring before plywood goes in.
20121124_122520.jpg20121124_122508.jpg20121124_122532.jpg20121124_123101.jpg20121124_123118.jpg
LowTech
162
Arizona
That looks good. Are you going to have something below the doors, or will you have to put the tailgate up to close it up?
LowTech
162
Arizona
So there's no using it w/ the tailgate down? If you're sleeping in it you'll have to have the tailgate up, and then be able to put it down before you can get out?
I think I'm confused.
Lextreme
SGV Ca.
Yes when we sleep, the tail gate goes up. It is a 3 door type of opening. People can not lock us in when we are sleeping. When we get out, we can get out with or without tailgate being down. However, it sould be easier with tailgate down.
DUG
Senior Chief/Moderator
73
Mesquite, NV
Any updates? Is it done? Has it moved from the spot I parked it in? If so, how much fun was it putting it back with the deuce?
charlietango
20
Winnipeg
now, not to play devil's advocate I really like the idea for the record and you did a great job, but have you considered the 'roll over' factor? It would be a shame to dump that trailer over with all that work done. I've seen more than one tipped and contents dropped, mind you all the ones I saw were off-road but it can happen bouncing off rough tracks or something when the 360 degree pintle allowed the jumping trailer to go.
I thought of a similar project but worried about this.
