M1078 A1 transfer case
Skyhawk13205
312
Alaska
The SN cutoff for the bad bearings is pre 6510072174, SN for the composite thrust washer is post SN 6511014364.
The Allison documents that are applicable are
SIL 17-WT-11
SIL 29-WT-96
GCecchetto
294
Woodside CA
SIL 17-WT-11
SIL 29-WT-96
So, my trans serial number 6510837456 which falls in between those two numbers. So, does that mean I don't have the bad bearing but also not the new composite washer?
Ronmar
8,220
Port angeles wa
I believe so. They replaced the original spec roller thrust-bearing with a different roller thrust-bearing, then they replaced that second bearing with the current spec thrust washer...
