M1078 AC install
coachgeo
3,553
North of Cincy OH
@Xengineguy ..... am I correct that Waterloo's compressor mount also go on Driver side? I have one.... just not at stage to mount AC.
If so....... does make me wonder if your Idea could be used to mount a second alternator. My concern is would it have enough belt wrap and if it would/would not work with Vbelts (long story.... but doing so would help me solve some issues not 12v related).
Got no working alternator right now on the truck.... but have three non Neihoff 24v's have to use. Thus need to do Alternator sooner than AC. Least one of them and 12v convertor I have ready to go also.
One of the 24v is slated for the APU; replacing its 12v
GeneralDisorder
6,216
Portland, OR
What's the compelling reason for locating the compressor on the other side of the engine? The hose connections for the evaporator and condenser are on the driver's side. Belt wrap on the pulley looks a little light. Probably not an issue.
Just observations. I'm sure it will work fine.
Xengineguy
831
USA Indiana
I didn’t want to spend the money for the pulley and mounting brackets. And spend the time to install the brackets on the drivers side.
Sounded like quite a project all by itself. The ac hoses route down the right inner frame rail and cross like the heater hoses.
In front of the radiator. As you can tell I don’t mind fabricating and trying something different.
