M1078 Fuel Tanks
ogdobber
10
Los Angeles
For the amount of work you would gain 5 gal maybe Easier? Easier to swap an m939 series tank on. They are 81 gallons and around the same size
Some folks have used that L section for generator fuel tanks to be mounted.
Thank you great info. Now the search for a m939 tank begins
Sent from my iPhone using Tapatalk Pro
simp5782
Feo, Fuerte y Formal
9,496
Mason, TN
You want specifically one for a 923 925 927 or 928. The cargo trucks had the larger tanks. I may have one.
Boyce equipment would have one in Utah or jacks government surplus in Tuscon
Also check with member @silverstate55. He could have one near Vegas
ogdobber
10
Los Angeles
much appreciated, I gave jacks a call he’s going to have a look. We’ll see if @silverstate55 chimes in or even let me know if you have one.
-Mark
simp5782
9,496
Mason, TN
-Mark
M939 Cargo fuel tank is 44" x 25" x 17" tall.
LMTV tank is 44in x 27in x 17in tall
So swap should work easy enough. Tank uses a standard sae sender so it is available in different ohms and voltages.
