M1078A1 fuel starting issue
MatthewWBailey
1,897
Colorado
Yep, thats it, they made it real easy on the 3116 with a 1/8” npt port. Had an old oil pressure gauge from the junk drawer hooked up in a few minutes…
IMO, this is something everyone should check whenever you change filters… or install a dedicated gauge… I don't think I can possibly count the number of fuel supply issues I have troubleshot over the years.
i am kinda surprised cat stuck with the mechanical lift pump on the 3126/C7. Even ford, when they licensed HEUi from Cat fitted a 60 PSI electric pump/filter unit back near the fuel tank… At least that way any leakage leaves a wet spot:) a fixed pressure electric pump could be monitored with a pressure sw and an idiot light…
Here's the fuel psi at startup
MatthewWBailey
1,897
Colorado
Got it back together and it fired over immediately. No codes showing. I let it run 15 minutes. See video of fuel gauge above. I guess the new sensors did the trick. Fuel psi shows 80+. Gauge is a NoShok 0-100.
so far no leak on the compressor.
Ronmar
8,216
Port angeles wa
80 PSI at idle? Does it go up any when you rev the engine to high idle? Depending on where you look the pressure spec can vary. I have seen A0 specs from 7.5 minimum low idle to 65 psi max high idle. Are you sure the fuel return line or reg at the back is flowing properly?
just came across another one that says 58-76 high idle and 58-65 low idle, which is the first one I have seen that didn’t have a significantly lower pressure spec at low idle vis high idle…
MatthewWBailey
1,897
Colorado
Not sure of the regulator function. I was kinda surprised to see it shoot up that high. Could that return line or regulator be clogged with the same crap that was lodged in the primer pump check valve? I guess the filter would prevent that thou. I'll check on the high idle pressure tomorrow. My gauge line is leaking a little bc I was rushing and forgot to put Teflon tape on the npt threads.
Ronmar
8,216
Port angeles wa
Its possible… you have another regulator on your second engine to play with? A quick test for the return line would be to simply connect a different line to the regulator output and run it into a bucket to take the installed line out of the equation…
MatthewWBailey
1,897
Colorado
Yes the other engine has a complete set of lines. That's a good idea. I'll try that.
MatthewWBailey
1,897
Colorado
I changed regulators and it's going to 80psi but not above. At high idle it drops to 76-78, then back up to 80 at idle. I haven't pulled the return line off the tank yet. Maybe that tank elbow is clogged. All my lines are new.
MatthewWBailey
1,897
Colorado
I took a 70 mile drive with it. I pointed one of the digital cameras at the fuel gauge to monitor it. Espionage tactics. At highway speed at 1400rpm the psi is ~70 pretty steady, with these strange occasional dips down to 50 when I throttle up hills. Downhill with zero TPS, the psi goes up to 90 at 2000rpm. So that's concerning.
I ran Cat ET live the whole way, no codes shown. When I started up, it showed a "cold mode" status flag. Does that limit the engine I wonder?
MatthewWBailey
1,897
Colorado
Did you ever run the regulator output thru another line into a bucket?
Just did the bucket test with the return line off. Barely any fuel came out white at high or low idle and pressure stayed at 80. I guess either the regulator is bad or internal blockage? Strange that 2 regs would be blocked.
Ronmar
8,216
Port angeles wa
Yes that is strange. the test port/tap is after that second filter right? It should be a straight shot from the second filter output to the front of the head via a hardline, past the injectors in the gallery in the head, to the regulator in the back...
Is it possible that the hardline up to the front of the head is crimped/crushed somewhere along the way? there should be quite a lot of fuel coming out of the regulator even at idle, let alone at high idle...
On mine I can pump 10PSI in the system on the gauge with the primer button. This pressure builds against the regulator, and I doubt if I would see anything on the gauge with the regulator core pulled(you can disassemble the reg on the 3116). I wonder what your gauge shows when doing this with and without the regulator installed. without the reg installed you should not be able to build any pressure on the gauge, especially on a gauge installed after the last filter...
MatthewWBailey
1,897
Colorado
More info, No Progress. I pulled the primary fuel hard line and it is not crushed. I blew it out with air but it was clear. It's an exact match for the one off the crate engine. Reinstalling is an adventure due to the hidden boss on the front of the engine. Still pressurizes to 80 on startup.
With the truck off I can push the gauge up to 24psi using the primer pump at which point the button is impossible to push in. So, I'm at a loss. Unless I simply have 2 bad regulators?
