M1078A1 fuel starting issue
Ronmar
8,401
Port angeles wa
well if the reg is the only thing providing the restriction and 2 different ones are doing the same thing, it is probably right. it just seems a little high from some of the specs I have run across...
MatthewWBailey
1,905
Colorado
Been busy but made progress on this today. Pulled the reg and pumped the primer, no pressure built up, just fuel pouring out of the port. I had already purchased a new regulator for $250 (cat 1420371)So installed that with new o rings. Pressure dropped to 55-65 at idle same at high idle but with less gauge sweeping. Gauge is dampened but sweeps around 60 +\-5 at different frequencies depending on throttle pos. I guess the other regs are different?
putting this to bed.
now onto the aux panel I bought to house my tach
