M1088 - Can antilock brakes be added ?
Reworked LMTV
Expedition Campers Limited, LLC
1,178
TN
First, I big thank you for all the of the people have responded to my zillions of questions as a Newbee. Suprman has been especially helpful.
So I have an M1088 without antilock brakes. Anyone attempt a antilock conversion using the newer M1088a anitlock brakes? :razz: I'm going to do the Fast Axles anyway, so might be a good time to this too.
Reworked LMTV
1,178
TN
I think it would be cheaper to sell yours and put that money and a bit more towards an A1 truck if abs is important to you.
You are probably right. How are the non ABS LMTV's in the snow? I never had ABS when I lived in MI. Parents could be heard screaming to children "Pump the brakes!" Lol. I know you can exhaust the air fast if you pump the brakes in an air system.
Suprman
697
Stratford/Connecticut
You will want to drive slow and cautiously in the snow. ABS or not its a big heavy truck. Dropping tire pressure will help in the snow. Not much helps on ice unless you have studs or chains.
