- 141
- 1
- 18
- silver creek ,NY
Soooooo, not a fan of the spaghetti mess under the fuse block. It was nice when they labeled every wire so you could locate things easier. On my new FMTV tractor, there is one fuse socket (cb44, "trailer tail lights") that appears to have melted. The wire coming off the fused side is missing (the one that caused the melting). There is a socket missing out of the relay for (K31) "hazard warning", that appears to be the power supply slot. There is a random wire that was sticking out with what appears to be the correct plug to plug into the empty slot at "k31" but it looks like it had a second wire crimped (poorly) in with the one that is still there, and there is evidence of a little wire casting melt. There is also a path of destruction leading from the burned fuse, to where the empty socket is. The random wire leads to the power supply side of "cb74-hazard switch", which also jumpers over to power the fuse for "CB71-flasher". So, I took an educated guess, and connected another wire into the lonely plug, then put it in the lonely socket at k31, then took the new wire and connected the other end to an inline fuse (15 amp), then plugged it into the power supply side of the melted socket. Doing so, gained me brake lights, but still have no turn signals or hazard warning lights. Park lights and headlights are fine. I am guessing the flasher unit is shot. If anyone can find a wire schematic for the flasher system please let me know! Here are some pics for reference.![IMAG0113.jpg IMAG0113.jpg](https://www.steelsoldiers.com/data/attachments/463/463537-c1a21f2d3fc4b28d6764b8dcc67933f0.jpg)
![IMAG0112.jpg IMAG0112.jpg](https://www.steelsoldiers.com/data/attachments/463/463538-6b60b6cc482b6f484b60480a250240fe.jpg)
