- 141
- 1
- 16
- silver creek ,NY
Nice guess suprman, it was a code for sump temp fault (low).
Sounds like Ground fault, Battery connection, or mayyybe Reverse Polarity box?Also, the starter button is still intermittent. When it does anything, it acts like it is barely getting a connection, and the solenoid rapidly engages and disengages. I tried another starter button, and it did the same thing. All connections under the dash look good, and connections at the starter and solenoid are all tight. It starts perfectly when I jump the two large posts on the auxiliary solenoid though. Still stumped there.
Should be able to find info in the TM's for that?The reverse polarity box is an unfamiliar animal to me. I don't know how to check that.
