M109 Trailer
sail-bum
Buford, GA
I am after that same idea, what trailers has the 109 box been mounted to by others? I am just trying to learn from other peoples success and or mistakes before I make the jump.
Darwin T
10
Port Arthur, Texas
was it another trailer or did you use a deuce frame? if you used a deuce frame what type of axles did you use (M105, dual tire axles from a genset trailer, or?????)? did you set it up with the airbrakes like an M105a2? :shock:
PS. Awsome trailer. :beer:
SCSG-G4
PSVB 3003
3,298
Lexington, South Carolina
Neil's is on a deuce frame that was cut down and shaped, if you will read the writeup that was done on it, all the normal questions should be answered.
Darwin T
10
Port Arthur, Texas
thanks, i plan to make a trailer with either a m35 bed or and m109 box but have not got that far. just saw the thread yesterday where the guy was asking about the m109 box or some other box m2?? and someone posted this link. i have not really started the search. buy i will.
oldMan99
12
Polk County, Florida
It`s in a thread started by Sevo, 109 cnversions I think . It was a job but with alot of help from my son Brian at least the outside is painted.
I hate "Search" as I always seem to get zero or 900 hits... aua but I "THINK" I found the thread. I hope this helps....
http://www.steelsoldiers.com/deuce-...ing/38018-m109-trailer-conversion-thread.html
Upon further reading I also found the following thread that is of a different build but closely tied to this build:
http://www.steelsoldiers.com/deuce-modification-hot-rodding/43811-m109-camper-conversion.html
If you are at all interested in doing a project like this, both threads are very worth reading.
