Backwoods deuce
- 57
- 18
- Tallahassee FL
So I picked up a M1102 out of Albany last Friday. I’ve switch the harness pigtail over to civilian 7 blade and changed the rear incandescent bulbs to 1156 and 631. Also noticed the 90a wire broken with no end on it and after some searching I believe this to be a ground so I put a eyelet on and grounded it with the white ground from the 7 blade on the stud next to the connection holders underneath. I now have all my light functions minus the front amber marker lights Being very dim. Rear sides and rear center are bright as can be. I should also note that prior to fixing the broken ground I had very dim front markers then and that’s how I found the 90a problem. Is there another ground I’m missing? I’ve called myself looking in the TMs I’ve dug up via the web to no avail. Oh and grounds inside the covers are tight. This trailer is 2012 so the markers are LED.
