M129A2C Camper Conversion
mdmorganwife
15
Forsyth Ga
Just about got all that we need out of the donor camper. Not bad for a weekends work :naner:
swbradley1
Modertator
1,898
Dayton, OH
The donor is almost the same color interior as our 2009 Keystone.
If it hadn't been for the ice meteor hitting it at Marengo last year I'd like to pull ours apart but the expensive new roof keeps that from happening......
11Echo
95
CT W. R.
added pic
Looking good! Real nice work.
I'll be watching your progress for ideas in case I decide to do this to one of my trailers.
3dAngus
102
Perry, Ga.
I've got one Daniel. Maybe I can meet you at Robins one day this week or next. I'm heading to Palm Bay tomorrow to drop off a trailer so I'll be out of pocket for a few days.
mdmorgan
AM3 U.S. Navy
1,085
104
Forsyth, Ga.
Just toss it in with the stuff you are bringing to the rally, I'll get it from you then.
zout
155
Columbus Georgia
Looking awesome as we all expected - I bet that spray foam makes a huge difference in temp and exterior sound. Cannot wait to see this one.
mdmorganwife
15
Forsyth Ga
Ok, they way over did it with the foam...... Anyone know of a better way of trimming the foam? We are using a hand saw to trim it between ribs and a crowbar to expose the ribs... We got the closed cell so we won't have to worry about it soaking up water. Which also is more rigid
goldneagle
1,203
Slidell, LA
How about a BOW saw used to trim tree branches. If you can turn the blade 90 degrees it would be easy to use. Another idea is a HOT WIRE cutter shaped like a bow saw. Use an old train transformer as a power supply. You can find NI-CHROME wire on the net. PM me for more detail.
zout
155
Columbus Georgia
I have delivered machines that cut styrofoam with the hot wire application what I have seen it sears the cells shut. Explanation or example would be take a nylon rope after you cut it and to seal off the ends you light it up making a seared ball at the end so it does not unravel again. When the hot wires were used it seared the areas of the foam cells shut - therefore adding to the loss of insulation factor - with the open cells as when cutting it - it did not loose its integrity.
Ain;t my couple hundred dollars worth of foam - gave the best solution I could Bro. Still looks fricking AWESOME Morgan's.
