JasonS
- 200
- 63
- Eastern SD
got mine from amozon and it was the wrong plug size did anybody else have this issue ???
No, but I got two from NAPA that were the wrong wattage.
Watch the video again. At the 15 second mark look at where my fingers are.according to the video above where do you put in the element if you have a heater ? I have one on the way and would like to know.
I found the package that the one I bought from Amazon came in. Perfect fit. Easy installation. I got this information from another thread before placing my order. I apologize for the redundancy.
KAT's Heaters / Frost Plug # 11611
600W / 120V
LR93521
It seems to work very well except for on the coldest days when temps are down in the 20's and below
How do we get in contact with Westfolk?I would buy from Westfolk, you get experienced tech support for your exact application that way. Regardless make sure to mount in the lower hole. If you have a cab heater move your heater return line to the upper hole and put the block heater in its place. This is what Westfolk reccomends, so im sure there is a reason for it.
Most, if not all early failures I have read about with these heaters on deuces have been when they were mounted in the upper hole, or plugged in before submerging.
Here is Westfolk's installation video.
[media]http://www.youtube.com/watch?v=G_x866oWPJk[/media]
You can leave it on the engine. The way most people use that needed it was to place a good sized magnet right at the hole and carefully file. The way I've done it is a little different. I have a nice course rat tail file on the ready. I turn the plug/element out and insert the file. Give it about 10 good and hard strokes on the front side(facing the radiator). Then put the plug/element back in. The whole time everything is being washed out with the antifreeze. You lose about a quart or so doing it this way. I like it best though because the filings are so small and light and the flow is good enough I am confident it is all being washed out. Just the way I do it. though.Found the article I was referring to above. Westfolk I didn't realize it was rubbing, I have the 600W unit. I finger tighten it but really didn't feel any resistance except the normal resistence as the threads make contact with the block. After removing the unit I saw it was scuffing on the copper coil near the base. About a half inch rubbed. How do you file? I would assume you saying the water pump would need to be removed otherwise the filings would drop into the water pump.
