91W350
- 59
- 48
- Salina, Kansas
Thanks guys, I suspected so.... I will try to pick this truck up. It looks good, if it runs as good as it looks, I will be a happy camper..... Which I suspect it would be great for! Glen
I know this is an older thread but I came across it in a search and wanted to add my knowledge on the 109 box.Yes pls post some pics, I never seen one totally empty.
I must contend a point though, the M109 has wood filled walls, and things, heavy things, can be bolted right on. On the S-280 - you must carefully design the mounting and preferrably take note to put the fasteners through the skeleton if possible.
One M109 box, the only one I have seen taken apart, had wood sheets inside the steel walls. I am informed that they do not have this stock.
