73X
- 9
- 0
- Farmington Hills, MI
TM you are the man well said. Carry on.
what's everyones opinion on the oil cooler plug being used vs. the lower or upper water pump plug?
My oil cooler has two more drain plugs on the very bottom. Mine have thread locker on them and I have been unable to remove them, but I imagine that one of them is coolant. I don't know why they would put two oil drains side by side.Hey....go for it...
Have you read the thread?
I think not.
This triggered my curiosity so I went and fired my truck up and let her come up to temp for 20 minutes. I took a IR reading at my defroster and the temp read 168 F (ambient temp is 52 F.)i used the plug just above the water pump it works great .i didnt have to move my heater hose that way
I then shut down and moved the intake for the personnel heater to the upper port above the water pump and fired back up and took the same temp reading at the same location in the cab. within 2 minutes I lost 28 degrees to the heater.
The personnel heater needs to be at the water pump location so that the impeller is forcing hot water through the heater. If you move it up it stagnates the water going through it and the fan blows the heat right out of the slower moving water before it can regenerate with fresh hot water.
I suspect that at lower temps the heater would loose more heat with the intake moved up.
Good call on that TM.
