greenjeepster
- 10
- 0
- Southbury, CT
Tm: your own measurements show heat going to the radiator. My measurements show heat going to the radiator.
When you put a heater into the coolant system it will heat to a peak temp for that wattage and then level off... I am using that feature to measure radiator loss by occluding the bottom radiator hose with blocks of wood and a c-clamp and at that point the water temp rises above the previous peak and the difference in temp is how you calculate % loss at the radiator.
Yes any heater in any location will have loss at the radiator. I am predicting that some locations will be more than others. The benefit of efficiency is that instead of risking your truck by leaving it plugged in all night you can put a timer on the cord and only turn it on 1-2 hrs before needing the truck and it will reach peak temp in that amount of time.
You are right... people are giving bad information... It started with the person who said they are only trying to be helpful and suggested putting a heater in the waterpump in the first place. Not even considering why the TM: said to put the personnel heater line into the waterpump and suggesting that people move it. The application was taken from a small car gas engine application which I will address the issues with making that leap Later. Nice of him to be helpful and to share his information, but they I have to ask why he is selling a 25.00 heater to all of us for 55.00?
